ajd
I was going to change the master cylinder piston and seals on my 1100GS because there was a weep. Went to remove the brake lever and imagine my surprise when the pivot screw wasn't there. At least, the head wasn't. It all makes sense now - it was weeping a while ago, I took it to someone to replace the seals, the weeping never got better but wasn't bad so I thought 'it was meant to do that'. I reckon the bloke either snapped the screw or found it was snapped when he got there so didn't change the seals and took me moolah anyway. Fascist.
If I've uploaded the picture right you can see where the screw isn't (between the throttle cable and the brake light switch). There's just the shaft of the screw up the hole, looks like someone has tried to drill it out perhaps to try to use an easy-out. I tried that too but it isn't cooperating and I reckon I'll damage the body of the cylinder further if I try again.
Anyway the job is now to replace the master cylinder. I guess this can be done with the brake lever left on (hope so 'cos it aint coming off...)? Any advice?
