marcopol
Some weeks ago I was filtering very slowly in traffic and executed near enough a full lock to the left. I noticed that the front brake started to come on on its own, not enough to stop the bike but enough to notice that the pads were staring to engage. I checked to see if any of the brake lines were under stress or were being stretched when the handlebars were turned in any direction and they are all Ok. Incidentally I do not have any bar risers fitted.
Today in a straight line the pads would not disengage when I applied the front brakes and then let go of the front brake lever. The pressure at the lever was rock hard indicating that the pistons were fully extended.They eventually released themselves enough for me to move onlyafter they cooled down. I took off the front calipers and the pads are OK and there is no obvious sign of crud around the pistons.
The obvious problem would suggest that the pistons are sticking and need to be cleaned but why did this happen so quickly. Before I strip and clean the calipers, which is a pain in the Ass, could it be the valve in the front brake resevoir sticking?
Anyone come across this problem before?
Anyway I cleaned off the pins lubed them up and it seemed ok. Then I sold it and brought a GS800 and have had no problems since
