Front disc come loose
Uncle-Fester
Unhinged
Kent, England
During my Pyrenees adventure the front right disc has started to rattle due to slight movement even though all the bolts are tight, are there shims or summat that prevent this that may have fallen out?
Sent from my SM-G920F using Tapatalk
Be prepared to be bummed heavily on the price of the bobbins and wavey washers!!
Yeah, bobbins and wavey fellas as mentioned above. Also fit the appropriate size stainless washers (20x8x1mm thick...I think) between the hub and the disc, the hub corrodes and wears so you end up with more clearance and a rattling disc but probably only on the RHS if you have an ABS ring on the left.
:thumb
Y the hub corrodes and wears so you end up with more clearance and a rattling disc but probably only on the RHS if you have an ABS ring on the left.
:thumb
Not if he has the wheel with the abs ring mounted on it's own specific lugs ;)
