Front swingarm gator plastic retaining ring needed
Not open for further replies.
bikemad
Ramsgate kent
My front gator was not fixed properly so Iv struggled n struggled,loosend shock so I could jack it up did almost manage to get it in position,but the plastic retainer slipped behind knuckles & was stuck I ended up breaking it in half :blast so if anyone's got a spare I'd appreciate it :thumb2
Otherwise looks like might need a new one :nenau then off with the arm to replace it.
Also means no riding in the wet till it's done don't want to risk the bearings.
If you mean the ball joint gaiter you might find something suitable at a motor factors. Dust & grit will be the big deal - gaffa tape should keep it clean until you get it sorted.
Yes the big ball gator lol it's stayed in place ok without the plastic inner ring cos it's not been pushed out of shape dislodged,got one en route & the socket to adjust the swingarm bearing £12 off eBay easier than cutting a slot in a new socket :)
