Yes, you probably miss the last gallon like I did when I used the stock-tank fuel pump assembly sucking-pipes. I also got max 32 to 34 litres out of it with stock internal fuelpump pipes.
Aceribis is the TT tank, just Touracrap written on it, like on many other products.
You need to have that Touratech 41 litre tank "enlargement kit" (costs 50EURos or so) for your fuel pump assembly, it gives more lenght to fuel pump's sucking-pipes, so it takes fuel from the bottom of the tank as far its possible. Stock pipes don't reach to the bottom of the big tank, so they suck petrol much higher, thus leaving lot of unused petrol into tank.
See here: http://www.touratech-usa.com/docs/09-100-0014-1.pdf
And you need to have that horrible two-lobes interconnect, so you get the max out of the two lobes. Haven't had problems with it. Mine's older model of the TT41L tank, with offroad style cap and from 18th century looking interconnects.
Taking off the tank I've got a trick or two to take it off relatively "odorless".
I get approx 38-39L out of 41L.
the most I've gone to is 410 but I am not sure if the last gallon gets picked up
When I empty it to fit new filter, it dos not seem to want to know if I put 5 litres back in, needs a few litres more.
Or is this because its on the mainstand ?
I have the Tourtech 41 litre tank, does the Acerbis have the horrible balance pipe underneath ?
make taking the tank off a messy, smelly, dangerous chore and I always think it will get damaged when I am miles away from anywhere.
