funduro rad leak
garry a
sandridge st albans england
my funduro project bike has sprung a leak in the rad anyone know if a repair is possible its not just a pin hole more like a cut across two of the cores or has anyone used araldite with any sucess:thumb nothing to loose if the rads scrap anyway
update on rad leak
well i had nothing to loose so i repaired the cuts to my radiator with araldite pinched it all together with long nose pliers as straight as i could then just glued it all up:thumb so far so good didnt leak even when the fan switch failed and it boiled up:blast thats next job.
usually loads o bits on ebay, tried the forum chaingang?
