I've just fitted an auxiliary socket wired direct to the battery because the canbus one won't work with my heated jacket.
The socket came with a 5amp in-line fuse, but the current ate that one immediately, so I put in the one that came with the Gerbing jacket which is a whopping 15amps.
By my, admittedly not very expert calculations, that means the jacket can take up to 180 watts before anything pops, which seems rather a lot.
When a fuse is rated at 15 amps does that mean it blows at that current level - or does it have to go higher than 15?
