G450X 45H 1500m
Hi, My start without any problem ( I not even know about press headlight before start the engine ) till one day:(
Yesterday It's start after lots.... of trays but idle rpm was higher then before so I stop the engine to try start it again but no way ...
What if crankshaft is crack?
What kind off problems You have ?
If I not fix the bike I have to pay for recovery from me home to BMW service (I haven't got van) so 60f recovery+160f (for just have look by BMW service)
I'm so sad now :( I save for long time for this bike and now I not even know what and how much total will costs :(
Look like is only 1 way to fix it - plug in to Diagnostic BMW G1 Computer
Nobody can help??:confused:
Not a lot to help you with....it's one of those problems that can't really be fixed over the internet. To be honest it is hard to understand what your exact problem is, I see the ADV forum has not been able to help you much either.
If you can get it started and it is running fast at idle then you can adjust this, you will find out how in the CD manual you should have got with the bike.
If the problem is more than this, unfortunately it is going to cost you to get it looked at. Either ask a friend with a trailer to take your bike to BMW at Sunderland, or ask the BMW lads at Sunderland to collect your bike, or if you have breakdown cover they will take it to the BMW garage if they can't fix it.
Your call... would be interesting to know what the problem is when you get it fixed.
HI, I thing is only one way ---->> BMW SERVICE IN SUNDERLAND
Is anybody have van our any other car our have somebody in BMW Sunderland to give me a lift from Durham to BMW Sunderland Please ??
I got bike to weeks and only ride 1 day :( wtf BMW ?? Nobody can help
3 years saving for have bmw :(
60f for recover(form Durham to Sunderland) :( plus ~160f for BMW just for have look omg I just got a bike and it's not easy get extra money for service.. I hope so it's not crack crankshaft ;(
But than all anway
But thank You all anyway
Hi again,
Finally Mick Kendricks form Sunderland pick up the bike.
Hi try have look in my garage but nothing.. he have to connect bike to PC
I just call Him and: HAVE NO PROBLEM IN PC LOG :( so hi have to have look on it tomorrow :(
What kind of errors You can see in long??
For example:
Bad connections between cables
Low battery
No ignition
Bad spark plug
What if goin on?? BMW Sabotage >>?? 1 week bike still not diagnoses :(
http://www.advrider.com/forums/showthread.php?p=18709988&posted=1#post18709988
All cable fixed but bike still not start.
Right, I was a view bikes as BMW said that it wants to further diagnose the bike for me: O? So I had to go and watch as he goes after the diagnosis of 2.5 months. They showed me the main harness wires leading to the ECU and there about 20 tiny wires, including one nearly broken and the other is broken at the plug to the ECU.
I was told that the harness of cables must be replaced to continue the diagnosis and the cost with installation and VAT is 500 pounds but I do not know if this could be because bosses take me far they refused to continue any work on my bike. So I had to actually ask for and that they would undertake further work on a motorcycle mechanic for 10 min obtained permission from the boss.
I asked why so long is the diagnosis? As the route go veins diagnosis. They should focus on the electrical and not on the fuel system because it started from that suspicion.
If you want to continue the diagnosis of a bicycle must buy and replace the cable harness.
Now unfortunately I have no choice, because the stage of diagnosis is over. They came to the harness of cables that is causing the problem from the start of the bicycle (until your install and see if this is true) so my letter of complaint is no longer valid, and probably nothing I can do them because I diagnosed the problem ....... only pay them £ 680
