G450X stand length (dimension required)
darkhorse
North, London, England
Could someone with a G450X be so kind as to measure the side stand length from centre of bolt hole to stand foot.
Need to repair mine and want to make sure it's the same dimension as standard.
See photo
Thanks in advance
PM Timpo, he'll do it.
Sent from my iPad using Tapatalk HD
Buy a new one then you'll know the dimensions for a repair AND have a spare!
Measured from centre of bolt hole to the end of the metal leg. 360mm
The plastic foot at the end was worn so thought this was the best bet.
Hi, my G450x is starting to lean over quite far when on the stand, and it does not flick up when I right the bike. I have to kick it up, like a normal stand. Is it about to break?
Can you show us a pic of your repair job? Thanks
