Garmin 2610 Motorcycle Mount Photos
PanEuropean
Toronto / Zürich
Hello All:
I think some of this content and some of the photos have been posted elsewhere in this forum, sort of appended onto other discussions, but it's hard to find all the info in one place, so I have created a new thread with photos and comments, to make it easier for folks to get this information when they want to do an install.
I use a Garmin mounting bracket and Garmin power cable (Garmin sells this as a kit for USD $50, here's the link: Motorcycle mounting kit. This Garmin bracket comes with 4 small bolts and nuts which are intended to affix the Garmin bracket to a Ram-Mount backing plate. There are a lot of reasons why I like the Garmin bracket - Garmin tested it for tens of thousands of miles on motos before putting it into production, it is discreet, doesn't have the Garmin logo on it (so it doesn't advertise that you have a GPSR in the saddlebag when you park the moto somewhere), it's very lightweight, and it has a clear warning system that tells you if the GPSR is not properly secured in the bracket. The Garmin bracket also has a built-in recess to hold the cable securely when the GPSR has been removed from the bike.
To clear up some confusion about Ram-Mount products (and it's easy to get confused about Ram-Mount products, because although they make great quality products, they have a horrible web site) - Ram-Mount makes their own bracket to hold the SP 26xx, which I do not personally recommend, however, they also make generic hardware (base plates, arms, and various attachment clamps) which are used to hold other mounting brackets, such as Garmin's bracket and Touratech's bracket on the motorcycle.
I do recommend Ram-Mount's generic components, and Garmin had even engineered the 4 holes on their mounting bracket to line up perfectly with Ram-Mount's base plate (note: not Ram-Mount's bracket, but Ram-Mount's base plate).
So, to summarize so far, there are 4 items you will need to get:
1) Garmin mounting bracket and cable (link provided above). If you want the bracket only and no cable, the Garmin part number for the SP 26xx motorcycle bracket by itself is 010-10495-01, that costs USD $20 and comes with the 4 bolts (URL: Motorcycle mounting bracket (replacement).
2) Ram-Mount 2 1/2 inch base with ball, Ram part number B-202. This attaches to the Garmin bracket, they are designed for each other.
3) Ram-Mount Double Socket Arm. These come in various lengths. Choose the length to suit your motorcycle. For my Honda ST1100, I use the short (1 1/2 inch) arm with a SP 26xx, and the regular (3 inch) arm with a SP III. Note that the arms are made to fit various ball sizes, so be sure to get the right size. The one inch ball is standard and is appropriate for motorcycle GPS installations. Ram makes bigger ball sizes for laptop computer mounts.
4) Some form of Ram attachment to hold the whole mess to your motorcycle. Because my ST1100 has standard tubular handlebars, I use the U-bolt Base with Ball, Ram P/N B231Z. But, there are other Ram attachments available for different applications, including one that is made specifically to fit the left handlebar clamp of Gold Wings.
Now that you have all the components together, you can plan to install the device. Be sure to mount it in such as way that you have considerable freedom to adjust the tilt of the GPSR up and down - through at least a range of 60° of tilt. If you wonder why, go read the threads about all the difficulties some users are having with reflections from their GPSR display. If you have considerable room to tilt the GPSR, you can avoid this problem, which varies depending on what direction you are riding in, and where the sun is in the sky.
I suggest you hardwire the GPSR power cable to your motorcycle, rather than using a cigarette lighter style plug-in. Remember, the SP 26xx does not have batteries, so if a cigarette lighter style plug-in comes loose, even for half a second when you hit a pothole, the GPSR will reboot. Also, the connectors on the SP 26xx power cable are exposed tabs, so best to connect to a power supply that is switched with your ignition, rather than 'hot' all the time. This will save blown fuses if you accidentally rub the connector against a ground point on your moto.
Below are a series of pictures illustrating the different components, and the complete installation. It's quite important to install the GPSR on the centerline of your handlebars, first because if it is off-center, you will cause unwanted steering inputs when you press the buttons or touchscreen, and second because the GPSR has considerable mass (a lot more than a tiny GPS V, handy phone, or MP3 player, for example), and you don't want a big off-center mass messing up your steering geometry.
PanEuropean
What the final installation should look like (more or less)
On the centerline, instruments not obstructed, not sticking out so far it would interfere with a tankbag, installation allows for tilting up and down.
Here's a close-up of the components, showing how they all go together.
Note the allowance made for tilting the GPSR up and down as needed to cope with sunlight problems. This photo shows the short (one and a half inch) Ram double socket arm.
Ram-Mount "Handlebar and Rail Mount"
This photo shows the bottom end of the mounting system, which is obscured by the plastic cover in the photo above. Ram makes a whole variety of devices you can use to make the final attachment to your moto, so just choose the one best suited to your particular needs. Be sure you get the correct size ball (usually a one inch ball) on it.
Ram-Mount Base Plate, Part Number B-202
This matches up perfectly with the back of the Garmin Bracket. Garmin supplies the required bolts.
You can see this on Ram-Mount's website, at the bottom of this page: RAM GPS Cradles and Mounts. But, don't buy the RAM bracket for the SP 26xx, buy the Garmin bracket, and buy RAM's generic mounting components to hold the Garmin bracket.
Double Socket Arm, connects the base plate (above) with the point of attachment to the moto (below)
These come in various lengths to suit your needs. For my moto, I use the short one (1½ inches). A 3 inch and 6 inch model are also available.
Handlebar Mounting Bracket
This connects to the other end of the double socket arm, and is the final attachment point to the moto.
Note that there are many other RAM products available to use as final attachment points, if you want more information, go to RAM's Catalog.
Finally, here's a close-up picture of the Garmin mounting bracket for the SP 26xx series:
I like the RAM mount system too but their 'cradles' vary.
I used the RAM GPS V cradle as I believe it is better than the Garmin.
With the GPSmap 176 I used the Garmin cradle attached to a 2 1/2 inch ball base similar to the SP2610 here.
And just in case we have any other VFR800 owners looking in, the ball of the Handlebar Mounting Bracket bolts straight onto the two front tank bolts.
I forgot to mention - for those of you with SP III GPSR's, the automobile mounting bracket that comes with the SP III is already equipped with the 4 little holes that match up with the appropriate holes on the RAM backing plate. So, all you would need to get in addition to what has been mentioned is 4 little bolts and nuts to hold the Garmin SP III bracket onto the RAM backing plate.
The bolts and nuts are pretty 'product-specific' - the bolt heads are recessed (dish-type) so they are flush with the Garmin bracket when installed - therefore nothing protruding to cause damage to the back of the GPSR - and the nuts are a special design, with raised collers, designed to self align and be held captive within the far side of the RAM backing plate. So, my suggestion is that when you order your RAM backing plate, be sure to specify that you want the 4 bolts/nuts that go with it.
If you are using a stock Garmin swivel mount for a SP III, you can reduce the bulk of the assembly by removing the 'click and swivel' base from that bracket. Just find and remove the tiny Philips screw on he back of the Garmin bracket, then, with the Garmin bracked installed in a beanbag mount or normal automotive sticky base, tilt it "downwards" as far as you can. The larger plastic part of the bracket, which holds the GPSR, will come out of the round rotating base, which you don't need on your moto.
Picture of my SP III bracket installation is below. Exactly the same RAM components (except that the double socket arm is 3 inches long, not 1½ inches).
PanEuropean
Streetpilot 2610 direct wire
Great post PanEuropean! It was a big help in sorting out the RAM boondoggle...maybe you can help with the wiring of the Garmin bare wire cable. I spliced the red lead(with inline fuse) to the red lead of a batter tender connector and the black lead to the white battery tender wire. I get power with a tester across the fuse but SP does not work. It works on 110v and with the cigarette lighter adapter in a car. What am I missing here?
Re: Streetpilot 2610 direct wire
Can someone make this thread Sticky, please?
I am sure there are other mountings, and other people will want to discuss alternatives, but the opportunity to put a really good thread as a starting point, up high on the splash "GPS Info" page, might raise the signal-to-noise ratio...
Hi all,
Your getting good at this ...
As 'Pan European' suggest the RAM-B-202 round base but with a screw pack mentioned is a RAM-B-202-G1.
The arm is in 3 sizes, short is thumb length, standard is index finger length - its a rough guide, but pretty good when deciding what arm is needed.
Realising that we now discussing Pan ST1100 and VFR, there's a few pic examples in the RAM UK customer pic galleries. Please send me pics, as it broadens the knowledge to others out-there.
Regards,
RAM-Man
just keeping it up at the top boys.
My bike mount is on back order so we'll see how it fits once it arrives. Ordering the mount plate tonight
