Garmin 2610 mounting bracket urgently wanted
AndyT
Stuck in SE Asia.....Thank you Covid 19
I have just bought a Motorrad concepts mounting bracket which comes pre-drilled and tapped to screw on a retaining cradle. Can anyone advise (or indeed have a spare) Garmin holder that is of the 4 holes in a square type for the 2610 please let me know.
The RAM cradle that came with my kit (GPS wharehouse deal) is the Ram mount and the distance between the holes is not the same as pre-drilled in the Motorrad Concepts mount. The bracket that came with my Garmin SP111 wiorks a treat so I am after s similar thing for my 2610. I'm off on holidat Thursday morning so would appreciate if anyone has a spare one or knows where I can get one quickly please let me know.
many thanks:bow
AndyT
if its the standard garmin mount for the 2610 i have one i'm not using
Is that the bit :nenau
many thanks:bow
AndyT
Not sure what the 'real' question is .. so an all round answer ..
RAM GA9 cradle has two holes and uses a diamond base (2 hole fix pattern)
Garmin cradles, such as SPIII and 2610 (010-10495-00) has four hole AMPS pattern fix as posted by RC so its either RAM-B-202 round base and rotate holes to locate or there is now a square plate with four holes alternative, RAM-B-347 .. but .. The diamond base to pick up on diagonal holes (2 only) on the 2610 cradle if you need quick get out of trouble solution.
.. hope some of this is useful
Thanks for all the responses guys. RC Mad has the very thing I am after and hopefully it will be winging its way to Scotland tomorrow - Top Man.
Steve, apologies for not being clear but you answered my question anyway. I couldn't use the 2 RAM brackets with the ball on as they don't work with the MC mount. The motorcycle mount kit is what I needed but I already had the power cable in the kit I got from you earlier with the 2610.
Mr Gorilla - thanka for the reply but thats for a 1200 GS and I have the 1150.
Thanks everyone looks like I'm sorted - Happy Hols for me, just need to learn how to use it now:o
HGave Fun
AndyT:cool:
