Hi guys I need to borrow some of your wisdom.
Just had a message from an e-bay shop ( I think it was Nomoremaps) they say I can't imput a full 7 didgit post code in the 2610, is this so?
What can I do to find a particular address?
Can I use a full post code to set a route on the PC, and then imput it in to the 2610?
Can I imput a short post code in to the 2610? Or is the 2610 not post code compatible. In which case which GPS 's (compatible with a motorcycle) can be set up whilst away from the computer using a full post code?
Cheers Val.
Cheers Val.
