Garmin 340 help
Jonny675
northumberland
for the past year this sat nav has worked faultlessly,until recently.
I have it hard wired to bike when I switch engine on no problem switches on however it now starts to disconnect from power,your riding along then wants to switch of so you have to press cancel and run off internal battery then the power comes on again.
I have cleaned pins and the sat nav,is this a common problem do the charging cables fail,I have checked all wiring on the hard wire.
