Hi Phil:
I wouldn't get too excited about the 'historical averages' numbers. I've looked at the averages on my GPSR, and they are pretty close to the numbers that are used nominally in MapSource as defaults.
I think (I'm guessing here) that these historical averages are used primarily to fine-tune the estimated time of arrival display. For example, if you are travelling on arterial city roads in Detroit, MI, your average speed will probably be about 48 to 50 MPH (the roads are generally posted as 45MPH), but if you are travelling on the same class of roads in Toronto, Canada, your average speed will probably be closer to 35 MPH (the roads are generally posted at 35 MPH). This difference in speed actually accomplished is not going to change routing very much, because if the GPSR is trying to construct a route to get you somewhere quickly, it's going to choose the arterial roads in either case. The only difference will be that you'll get there faster in Detroit, and eventually, the GPSR will learn that and that will be reflected in the estimated time of arrival that is displayed as you progress.
Where it does make a difference (and this is about the only place I have noticed that it makes a difference) is in Germany, where the average speed of travel on the Autobahn road class is so much higher than the default. In this case (only), it makes sense to tell MapSource that you will be averaging 85 MPH - or 110 MPH or whatever - on the Autobahn, because then the routing engine in MapSource might take you a bit further out of your way than normal to put you on the Autobahn.
This is the kind of thing that would be worthwhile doing if you have a really long trip to plan, not just for a trip to the milk store.
What is useful to know is that you can use these 'average road class speeds' in MapSource to keep you
OFF the controlled access highways if you don't like them. If I am planning a recreational motorcycle trip, I don't want to be riding on interstates (motorways), because they are boring. So, I set my average speed for interstates in the MapSource application to 31 MPH, and then tell MapSource to calculate the fastest route for me. Because the secondary roads now have a higher average speed indicated, MapSource will avoid the motorways like the plague, except when no other logical route is available - and then it will use the motorways only for the shortest possible distance before getting me back onto the secondary highways.
Michael
