Garmin GPSmap 276C firmware v3.10 available
  • Thread starter Thread starter BurnieM
BurnieM
Changes made from version 3.00 to 3.10:
* Fixed problem that could cause the unit to turn off when the map heading line is enabled.
* Fixed problem that would prevent changing the CDI scale using the zoom in/out keys in Marine mode.
* Improved readability of map label text in Automotive mode.
* Fixed the Sun & Moon page to update the date and time when using the 'Play' and 'Fast Forward' buttons.
* Corrected 'find' operation behavior when a diacritic character is highligted.
* Changed to use 24x24 custom waypoint symbol in connection with xImage.
* Fixed functionality of projecting a waypoint by using the find menu.
http://www.garmin.com/support/downl...ails.jsp?id=527
CAUTION: this update will clear your waypoints,routes and tracklogs, reset the unit to factory defaults and think that it is in Kansas !!
