Gear changes
  • Thread starter Thread starter johnnycash1980
johnnycash1980
Hi,
I have an 1150 GS. Yesterday whilst riding through traffic, my gear changing started playing up. To begin with I couldn't get into third. With a bit of jiggling around of the pedal, I could get it into third, then it wouldn't go down to first! Then it appeared to clear up. Today the same thing is happening. I have only done relatively short distances through traffic so havent really been able to give it a good run through the gears. I had a look in the dark just now when I got home and the pedal does not seem to be returning the the neutral position after changes.
Any ideas?
There's a cylindrical bush that the pedal pivots on, which gets filled with road crud. With a bit of careful disassembly, you can remove it without having to take off the entire mount. Give it a good clean and regrease, and everything should be good as new :thumb
If you do decide to take off the whole mount, the bolts that hold it on are glued in with threadlock and will come out a lot easier if you heat them up.
Thanks!
Will have a look at the weekend when I have some daylight to play with. That sounds like what is happening.
Cheers :)
