- Joined
- Jan 3, 2002
- Messages
- 1,481
- Reaction score
- 1
Really
Not got a manual to hand and haven't checked diagram, but
After I changed my gearbox last autumn I guessed on the connections for (I think) the neutral switch as no obvious signs which of the two wires went to which connection.
Since then I have always had to pull the clutch lever in to get the starter to engage, whether the motor is in gear or nuetral.
Does it matter which way the connections are on the neutral switch or is it coincidence
At w/e the starter just gave up all together - or rather the power to starter. The clutch cut out switch is seldom used, wereas I've been giving it rather regular us so I'm guessing my problem is there, just wondered if the neutral switch could have any affect?
Be interested to know whether those wires have to be one way rather than another (I'd have thought 'right way - green light in neutral', 'wrong way - green light in gear')
Perhaps non of this is the cause and it's all down to the daft circuit board not lighting the bulb, the weak switch gear failing the clutch switch and owner neglect Bit sick of parking on hills already though
