Done the valves. changed the oil and filter. changed gearbox and final drive oil. fitted new plugs. Connected new twinmax.
Previously made a balancer with tubing and oil, but was never happy with it. If the balance is out by any significant amount, it just sucked the oil out one side.
Using the Twinmax, with its sensitivity switch, you can fine tune it all through the range to an amazing accuracy.
Tried to get it to tickover like a harley, but failed.
When I had the injector to bits recently to see if I could stop it rattling, I put the throttle stop screw out of adjustment. Seemingly this is something you must not alter, or the world stops revolving ... or something like that, but with the twinmax I was able to get it set again.
A good wee tool.
Its amazing how much difference it makes with a decent servicing. I thought it was running perfectly.
Think I will do myself now.
What do we have here ...... blood pressure tester, thermometer, anal probe, cholesteral tester kit, vibrator ? ........... Louise, whats a vibrator doing in the medicine cupboard ......
A good wee tool.
