Givi E52 and Touratech Standard Set Panniers.
  • Thread starter Thread starter SNM
SNM
Folks
I'm thinking of buying the Touratech STANDARD aluminium pannier kit
35/41 litres for my 2003 R1150GS. Will I still be able to fit my E52 top box when the panniers are in place? If anyone has any pics of this same set up I'd like to see them.
Cheers, Steve.
Steve,
Welcome - but this is the "I'm new here i'd like to introduce myself" section - you might like to post this in one of the technical or equipment sections :thumb2
Hi Steve
I'll move this thread over for you to the Technical section .... good luck with your quest.
I've got the special set of TT panniers on mine. They fit in a bit closer, and I use a E50 Maxia topbox when touring. It is a bit close and I find I may have to jiggle the TT lids a bit to ease them out, granted it's a bit trickier when there's a load of camping gear on the back as well. Basically, it'll work fine because I've had no problems. The Givi rack is attached to the GS original rack.
Many thanks for your reply. It sounds like the set up I had intended might be a bit too snug. I might have to consider some other arrangement. I already have the E52 fitted. Thanks again.
