Givi Maxi E52 Stoplight
  • Thread starter Thread starter scotty42
scotty42
Has anyone fitted a Givi box with the integral stoplight to the 1200GS?
Givi lights
Hi Scotty
I think if you search back there was a thread on this, if my memory serves me right you pick up the power from the brake light switch, but dont take my word for it , try a search , I'm not too good on these here pooters ! Mike.
Thanks Mike, had done a previous search with no results, tried brake lights and got it this time.
Do a search on my username, Vampire, and you will see a number of entries on "Givi top box stop lights" and the Touratech TPS 15 power module.
In brief, there are a number of successful approaches, but I found that wiring up a relay is the safest. Others have reported successfully taking power directly from the bike's stop light, so that is certainly worth a go as the simplest solution. The worst that will happen is that the GS's circuitry will complain, but once you disconnect your additional wiring the system resets itself.
Can be made to work.
Good luck.
Thanks Vampire, did the search on your name and found the other Givi info
