Sold GoPro twin camera bike recording system
The Heff
Co. Down, N.I
I have recently went down the 360 camera route and now have my previous recording system up for sale.
This unit has served me well over the last few years, recording memories from numerous bike trips. I found this set up to work well, giving the user numerous camera views. Front & rear, front & helmet, rear & helmet, bike to bike or just the helmet on its own. When one of the cameras is used independently it needs battery power. With 4x batteries you have all day recording. The remote has a good range, so you can mount the cameras on other bikes, but control it from the remote on yours. You can add more cameras to the remote if required.
The cameras are 2x GoPro Hero 4. Both in excellent condition with NO recording or playback issues or pixel problems on the rear viewing screen. On the photo with the two cameras, on the bottom one, there is a small crack on the silver frame on the top right corner, but you really need to zoom in to see it. Just trying to be honest with the description, as this appears to be a common issue. Both cameras have all the rubber doors that cover the SD card slot and micro USB ports. These are often easily lost but these are all there.
There are 2x special waterproof cases which have a power connector inside the case, so both cameras can be on all the time when connected to the DIN plug via the 12v power source. The leads are long enough to connect into the 12v socket at the rear seat using a 90 degree DIN plug with 2x USB ports. You MUST NOT use the batteries when they are powered from the bike.
There is also a GoPro remote which is paired to both cameras to allow you to switch them off/on and record without stopping the bike. You can also switch the camera modes too. Supplied with additional remote mounts, one of which hasn't even been opened. The remote can also be powered and used at the same time via USB
Also included are 2x normal camera cases, one clear, one black. (I normally used the black one when mounted on the helmet.) Various additional mounts, brackets, rear camera doors, spare opening catches, and the GoPro tightening tool There is 2x original GoPro batteries, with a Smartree charger and 2x further batteries. This charger will charge the batteries from the bikes power socket, but you need to disconnect one of the cameras, or power from another USB socket. So if you are using 2x batteries, you can charge the other 2 on the move.
I will also include 6x 32gb Class3 micro SD cards and adapters already formatted to use with the GoPros.
The user guide has the passwords and camera access codes inside.
I recently checked a well known auction site and good GoPro Hero 4 cameras are going between £60-75.
Hoping the sell this all as one package
2x GoPro Hero 4 cameras
2x Powered waterproof camera cases USB
1x 90 degree DIN plug with 2x USB ports
1x GoPro remote and charging lead
1x battery charger and USB charging lead
4x batteries
User guide
GoPro tool
Various GoPro mounts, arms, spare doors, spare clips, sticky pads
6x 32gb Class3 micro SD cards and adapters, giving you hours of footage
If there is something GoPro related that I've missed and I find later, I'll include that in the sale too.
£200 posted to UK address
20250325_145246.jpg20250325_145306.jpg20250325_145340.jpg20250325_145407.jpg20250325_145429.jpg
Forgot to add the memory card photo
Just for clarification, these are NOT Class 3 as mentioned above, but Class 10 UHS 1 cards.
All compatible for use with the GoPro, having used them in these actual cameras.
All previous recordings deleted and re-formatted to full capacity today.
