Gecko
You may have read in the thread about the version 2.30 software being released for the GPS V that I have encountered a problem since upgrading.
I would be very grateful if any GPS V owners/users out there check how their tracback works and let me know if it is before or after they upgraded to 2.30.
Before the upgrade I was able to call up saved tracks and rerun them . The on screen view was always very similar to the normal routing screen view i.e. a bold grey line would highlight the road you needed to follwo and the grey line followed the road exactly.
After the upgrade the bold grey line has disappeared and is replaced by a weak line that looks a bit like this ' =======' and it no longer follows the road - it now points in a straight line from point to point. There is a 'lock on road' feature which I have tried in both ON and OFF mode but it makes no difference.
I have been in contact with Garmin and 2 different techies there, one in Garmin Europe and the other in the USA have told me that the tracback funtionality as I have described Before the upgrade was never like that - they are both telling me that it works as I describe in the After the upgrade .
This is bollox with a big dose of Bullsh#t !!!
: I know what this machine could do and have been using it for almost 2 years . I have recorded numerous ride out tracks and then re run them months later using the tracback feature. To be told by some spotty little herbert that it doesn't work like that has pissed me off somewhat.
Please check your GPS V's and let me know what your machine does because I really miss this feature on mine and I want it back.
Meanwhile if you haven't upgraded to 2.30 I suggest you wait a while otherwise you may have the same grief I now have.
: I know what this machine could do and have been using it for almost 2 years . I have recorded numerous ride out tracks and then re run them months later using the tracback feature. To be told by some spotty little herbert that it doesn't work like that has pissed me off somewhat.Please check your GPS V's and let me know what your machine does because I really miss this feature on mine and I want it back.
