Hi ladies and gentlemen.
I have a reoccurring problem with the retaining screw for the grab rail on my 1200 working itself loose. Now the problem seems to be that the nut on the inside has had its thread ruined. (can't remember what that's actually called) Not sure if this happened when the top box plate was being fitted or if the weight of the box plus vibration has done it.
Anyway the nut is welded/part of the frame, so not easy to remedy. I'm thinking of cutting it away from the frame and then getting a suitable nut to replace it (but not weld the replacement onto frame).
Does this sound like a plan or a cockup?
