gs 1150 abs brakes shaking
  • Thread starter Thread starter Cutter
Cutter
hi guys i have a 1150 gs with abs when i pull the front break,the front of the
bike vibrates more then my old bike , a gs850 whats worn if anything
I would check if you have a warped disc or anything is obviously loose.
I've just bought an 1150 GSA SE with Servo brakes and don't like thenm at all. they are non existent without the ignition on and I had a heart attack moving it out of the garage and found I had no brakes:eek::eek:
You need to get it sorted soon though as your brakes is No1 priority to be spot on.
Have Fun
AndyT:thumb2
Assuming its not the ABS cutting in and you have no loose bolts....
Put the bike on its centre stand and spin the front wheel.
Can you feel it drag at certain points?.
To isolate to a disc,remove one caliper and spin again.
You may be able to see any disc runout if you look closely.
