GSA Speedo too small - add a digital readout!
gsa2014
South East
Hi
I have always thought the speedo on my 2014 GSA was a little small. So pleased I went for the Nav as I use this instead to monitor my speed.
However I was looking at the multifunction display menu and found that I can add a digital readout. Trip button > SETUP > SPEED (current speed).
Forgive me if this is common knowledge or been covered but thought I would post just in case! You will also need to have the Pro on board computer option.
Regards.
I use this all the time. The only thing is, it would be good if you could convert to KPH for continental use
I find that I, by default, use the speed readout in the bottom right-hand corner of my Nav V in preference to either the actual speedo or the speed readout in the multi-function display.
- it has the added advantage that it reminds me what the local speed limit is too!
