H & B v TT
John Armstrong
Siorrachd Obar Dheathain
The pannier frames for H & B and TT look very similar. Is there any real difference apart from price ie £243 v £378 for a pair that I'm looking at?
And no prizes for guessing the cheaper option :rolleyes:
TVM
Measurements.
Hi John, I cannot answer your questions straight off, but I have a set of TT standard panniers.. pre-mounted. So based on my racks, i would say you need to know the measurements of the "mounts" and how far apart they are from each other.
My TT's came pre-mounted so i idnt not have to drill lots of holes.. i guess if you don't get your panniers pre-mounted, you could drill the holes to get the mounts in the right place to fit the HB bars..
That is assuming that TT and HB are using the same diameter tubing..
Hope that helps..
John
