handle bar for HP2
  • Thread starter Thread starter smarziano
smarziano
hallo,
Has Someone replaced it?
with the same dimension or different?
thank's Simone
hallo,
thank's Simone
yeah its easy you need to use bars the same diameter as the originals ,but you do need to drill and tap an m4 hole in the left hand of the new bars to accept the switch gear / grip assembly, but you need to get the new bars in position first and then put the grip/ switch gear assembly in position to suit you as once the bars are drilled they cannot be altered hope that is of help
I am using pro taper bars with a set of risers i got from Renazco Racing, this lets me fit a scotts damper and the bars end up being the same height and position as stock. The stock HP bars are quite tall so be carefull what you fit using the stock risers because it could end up being very low.
thank you, barkin pumpkin and scotsmun, for your helps,
Simone
I have another question: Has Someone bought a protection for HP2's paralever?
Except the BMW real axle guard in the photo and the swingarm (shaft) protector for rg-racing i don't know anything else for paralever protection.
I've seen this photo and I would like to find the producer.
That is two pictures now showing black swingarms, is this an aftermarket thing or just a coat of black after a rebuild?
