handlebar clamp bolts
davidgibson999
Coleraine
Hi
About to fit Migsel risers but haven't a clue what tool I need to remove the clamping bolts - they look like torx in reverse... Any ideas? I did a search and someone has suggested a normal 8mm socket which I started to use but it started to round one off so I'd rather use the proper tool.. thanks in advance
the old tools with my old and shagged 1150 a sweet, loads of stuff no idea what to do any of it and all that was missing is the bottle opener!
David, You need an E10 socket (1/4 inch drive) from Halfords. If you don't go for Halfords own you might need to check the barrel is thin enough to give you access as there's not much clearance.
