Handlebar Muffs: Which ones to fit over handguards?
Two wheels good
Bobbing up in Cork, IRL
Hi
Which Hbar Muffs will fit over handguards fitted with wind-deflectors.
Mine are TTech but they seem a similar size to R1150GS
thanks
David
Two wheels good said:
Hi
thanks
David
Only one that I know of, and that's the Tucano muffs, model 319 (if I remember correctly), and they fit over the standard R1150GS hand guards, I don't know if they will go over the TT guards. Send Steptoe a PM to see if he has any in stock, they really are the dogz bollox!!! :thumb
Just fitted a set of 319 muffs to my 1150 (thanks The Rover:)) - pretty sure that they won't fit over the handguard spoilers - you could always take the spoilers off :mmmm
they fit over the TT ones too :thumb
I had to take the TT spoilers off my standard guards to get the muffs on.
I have a set of Steptoes Tucano muffs :thumb
Blo0dy good they are too. Just using summer gloves again now :)
Jon :beerjug:
handle bar muffs
The way to go is if you have T. T. handgards just take off the spoilers, leave
the frames on and fit muffs over the top. I use Oxford muffs and they are aslightly tight fit over the frames but work well and keep the muffs away from
the brake lever. Got to go and see war of the worlds. ( wont be as good as Orsen well's version).
Dave GS.
The mirrors are the problem
Thanks for the replies. I'll investigate Tucano
On closer inspection I realise the mirrors are the real obstruction. It's an R100GS. My original post suggested 1150GS
regards
David
regards
David
The tucano muffs fit straight on, regardless of mirrors, you don't have to remove them - Tucano HERE
regards
David
i use a pair on my r100gs too :)
Thanks for the info.
Tucano muffs do look the business but I was looking for something ... eh..cheaper - that I could hack about on my green-laner too.
regards
David
Steptoe - have got any in stock please? I have asked on the muffs topic - but no reply there. I can't PM because it doesn't work....too technical forme. Anything more complex than a wheelbarrow and I'm snookered. :confused:
