hardwiring to an ADV
  • Thread starter Thread starter goggstrotter
goggstrotter
what's the best way to hardwire a GARMIN V to a 03 ADV without using too many 'scotchlocks', insulation tape, twisted wiring and general bastardy ?
is there a spare power socket under the tank ?. by the way the bike is ABS with SERVOS
Lift the tank without removing and hardwire across the battery. Ten minute job. Remember the inline fuse .5amp. Good idea as when you stop the bike it remains powered up. As most people remove the GPS before leaving the bike anyway the chances of draining your battery are virtualy nil...
Except in your own garage...
I bought a cigaratte lighter adaptor and cut it in half. Then used phono hifi plugs to reconnect it. Then add a phono plug to your bike and you can use the plug in the car or on the bike:D
GPS problems
Goggs, I have just bought a GPS 5 and I'm having problems getting started with it, any change you can help me out.......?
Regard joe
what's the problem, captain.
reply here with your problem or drop us an e-mail, will try to help you out
Gps
Goggs, I've got the hang of the Gps now, but thank for the offer anyway.
egards joe
