Has anyone tried....
Keith Chapman
North Hertfordshire
Here is one for you techies out there.
Just a thought, has anyone tried a Techlusion box on a GS which is still running the original exhaust, (cat , can and cat code plug)?
What would be the expexcted result?
1, No different to standard
2, Smoother running with no performance gain.
3, Smoother with a slight performance gain
4, complete no brainer
5, anything else.
Just wondering as the first mod people make is junk the cat, then a lot go for the Techlusion to get the fueling back.
As the GS is known to be lean even with the cat would a Techlusion richen the fueling and improve the standard set up?
Yup
No Surging
Also goes a little better once "miledly dialed in"
Techlusion only adds fuel so you can richen it up a bit and remove the problems caused by emision rules
And do your bit to kill the planet with yer cat on!!!
G...
