beemer pimp
Hi All.
Need some advice , after completing rebuild ( 1100rt ) back on the road, trying to iron out faults, so had small oil leak from head gasket , after retorque head problem seems to be solved but bike running rough , question is if there small leak ( just seep ) would that effect compression ? Then if retorque head will that effect throttle bodies balance ?
, next one will be GS
