Looking at the lights from the front of the bike, you have two screw adjusters between the two lenses. They are almost side by side, but one is slightly higher than the other. As you look at them, the R/H one should be the vertical adjuster and unscrewing it moves the beam upwards, I think. You have to stick the screwdriver through a hole in the cowell to reach the screw.
HTH,
