Shagley
Hi
I have a 2003 F650GS and the headlight is pathetically dim. I have changed the small bulb inside the headlight but this has made no difference at all.
The main beam is fine.
Is there a way of making this light brighter
I have done a search on headlights on this forum and it was suggested to replace the buld for a higher wattage (not sure if this is main beam or the other smaller bulb) but this may lead to shorting out the wiring - which would not be ideal!
Any help appreciated
?I have done a search on headlights on this forum and it was suggested to replace the buld for a higher wattage (not sure if this is main beam or the other smaller bulb) but this may lead to shorting out the wiring - which would not be ideal!
