AlanB
I would be interested in your collective thoughts and opinions on this.
I recently observed a bulb failure warning light on the RID (curiously, around the same time that I wired my satnav in, which may or may not be a coincidence), and, after looking up front, confirmed that the dipped beam bulb was in fact not lit. I pulled the bulb and swapped it with a spare. Same result. Thinking that the spare may have been a dud that I foolishly put back in the packet, I then used the other spare (I couldn't have put TWO duds back, surely).
This time, though, instead of refitting the bulb in the holder, I simply attached the power connector, and switched the ignition on. The filament glowed a dull orange colour for a split second, then it went out, never to re-light.
That split second of life has now got me puzzled. Is the bulb actually OK, and might the problem be with the controller unit? Or have I somehow frazzled two perfectly good bulbs (both H7, 12V, 55W)? I haven't dared swap the main beam bulb over (which I know works) because I'm a long way from home.
Any ideas?
Any ideas?
