Shez_ow01
Hi been advised several times to join this forum by friends, but never got roundtuit until now, and I am diving straight in with a problem on my 1150 GS.
Had a quick squint through the old posts, couldn't find anything to match this one.
The problem appears to be the result of either servicing it or washing it on the weekend;
I did a regular 10k service on Saturday (turned 70k Friday night) all appeared ok after the service. On Sunday I gave it a long overdue wash and re-applied acf50 to vulnerable areas.
Didn't touch it again until Monday evening when I went out to the shops, the bike was very difficult to start but eventually did, I put it down to water somewhere, anyway it was running well so I set off. Got 4 miles from home and it died, just stopped no misfire nothing, like I had switched it off.
The bike turned over well but just would not fire.
Got the missus out with the trailer got it home and parked it up until the next evening, tried it fired but would only just tick over touch the throttle and it dies straight away, don't touch it and it dies after a few seconds. try touching the throttle whilst starting it forget it.
it will do this for a while start at tickover, run very rough for 1 -5 seconds for a while until it gets some head then it will fire whilst cranking over on the starter but as soon as you release it doesn't fire. leave it cool and it does the few seconds thing again.
The fuel pump is pumping when cranking, a couple of seconds after and when it is running so that appears fine.
pulled the injectors and they are squirting something when cranking.
The plugs are sparking when cranking.
I though I may have water in the Hall sensors or something so got an airline to everything to no avail.
Any ideas????
TIA
Shez
Loadsa bikes
Any ideas????
TIA
Shez
Loadsa bikes
