mondials Guest Dec 7, 2007 #1 Can anyone tell me the procedures for completely wiping Garmin (2610) from my pc, with regard to the registry.exe? I need to reinstall Garmin to (hopefully) fix the problem . Thanks.
(RIP) Kaister Well-known member UKGSer Subscriber Joined Feb 13, 2003 Messages 18,477 Reaction score 3 Location not near to you Dec 7, 2007 #2 use a program called ccleaner - and set it to clean the reg after all the usual stuff it cleans out. . failing that - used regedit at the command prompt then remove garmin from local machine/software
