Irlanski
Hi All,
Just returned from 9,600Km trip to Odessa and Belarus! The Givi screen blew back to a steep angle towards me in Poland. I stopped to investigate only to find that of the two plastic right angle lugs mounted about 4" apart just above the headlamp unit one had sheared and the bolt from the other lug had found its way out. I ended up tie wrapping the the screen via those screen holes above the headlamp unit down to the bar below the headlamp in order to keep the screen upright.
And so I am wondering whats the minimum I can get away with replacing? Beause the lug sheared it means there is still plastic left in the screen frame. Can I get the plastic lugs alone and push them into the frame once the reminants of the old one are removed or do I need a new frame with lugs or what?
Where do I go the get the best price for the parts?
Help really appreciated....
