help identifying under-tank connectors
gog
Kirkcaldy, Fife, Scotland
removed my tank today to sort my dodgy fuel gauge and found a load of grotty wiring and what looked like mould. will re-wrap and clean, but found a couple unused connectors that i don't know what they are.
first looks like a diagnostics plug but it has 4 pins, i thought the 1100 uses a 3 pin diag connector:
next one is a small 2 wire one with one clear and one light green wire:
any ideas?
cheers.
any ideas?
cheers.
Hi Im pretty sure the 1st pic of the plug is for the lambda sensor, I remember getting shown one @ Jim Downeys on sat when I had My R11ooGS up there what the other 2 are tho .. :nenau
aha thanks, yes it could well be that as mine doesn't have a lambda sensor. looking at pics of the plugs online looks like it matches.
one down, one to go
2 pin:
B9193 Wheel-speed sensor front (Green & Shield)
Has the front ABS sensor been removed?
The big 4 pin is the O2 sensor interface.
