Help needed for Autcom interference ?????
Geno
Northern Ireland
I have the easi 7 and i want to use it on the goldwing , it works great with one headset ,but as soon as i plug in 2nd all i get is noise , just want to use for music and some chat , is there something i need to buy to stop this , i have tried swapping lids but it starts as soon as i plug in the 2nd helmet , Any help would be great ,thankyou ,
Geno .
Can you swap the headset leads at the Autocom end? If you do, does the problem move along with the lead, or does it remain on the same socket?
If it's the same helmet that causes the problem, as opposed to the same lead off the unit, then, to me, that points to an issue with the headset in the offending lid. It's not quite clear from your post what's happening in this respect, maybe you can clarify.
I swapped all leads and have 3 lids with headsets ,and each time i add the 2nd lid i get a few secs of music then just static . tried swapping but its fine with any one helmet but not 2 , any suggestions please , Thankyou .
Have you tried a single helmet, but plugged into the pillion lead?
I could be wrong, but I'm pretty certain that if you open up the Autocom the rider and pillion tail leads can be replaced - may be worth checking that they are both clean and well plugged in.
Dae
The Autocom sticker hides the screw
The stickers on the Autocom usually cover the screws. Have a feel on the transfer and you will find it. Leads are very accessible once the cover is removed
Regards
Nigel
update
Regards
Nigel
after another nite in garage , i swapped leads and headsets , so i used one full headset and my own lid with no mic fitted and all worked as it should . any more ideas please , will have a look at unit leads tonite
