anthonybrown
Hi all
I was out on my 2007 1200GSA when it just cut out,i turned off ignition switched it back on again let it do its check pressed the starter button and nothing the bike wont turn over and no fault showing on display. Had bike recovered back home i replaced the ring antenna and still the same. Have anyone here suffered the same problem and what was the fault. I've checked the side stand switch ,clutch switch and starter button and kill switch and they are all Ok. And the battery is showing 12.46volts anyone got any ideas.
Many Thanks
Tony
Many Thanks
Tony
