help- switched live
Smartbazza
Moira, Norn Iron
Hi all,
I have very little Knowledge when it comes to bike electrics. Can anyone point me to a switched live to connect into for my aftermarket heated grips. The oxford hot hands type.TIA
Barry
switched live
I presume you are just using it for the relay, and are running the main juice from the battery.
If you always ride with your low beam on I suggest you take it from that.
I have tapped this to switch my PIAA lights.
switched live
thanks,
The grip come with their own loom connecting two eyelets to the battery terminals but i want to attach one to a swtched wire so they cant be left on. live connection has an in line fuse.
Can you tell me exactly which wire (ie exact location) to use?
Barry
I assume the pre made loom includes a relay, it MUST have a relay to be connected via the ignition.
Whip the tank off and you will see a group of connectors under the tank, on the left hand, left as you are sitting on the bike, there are two connector blocks, the lower one has a GREEN wire coming from the bottom, this is the switched live from the ignition, test it with a multimeter.
You can connect to this for a switched live.
DO NOT USE SCOTCHBLOCKS, they are an abomination, using wire stippers cut into the sleeving at two points 5mm or so apart, just cut into the sleeving don't cut the wire, then cut away this bit of sleeving leaving the wire intact but with 6mm of sleeving removed, then SOLDER the wire you wish to connect to the green wire and insulate.
This method will produce a joint that will not fail.
Within this group of connectors you may see, depending on the age of the bike, an empty connector, this is so the Meta 357 alarm can be simply plugged in but is NOT an ignition switched live.
HTH
