HELP !!! Zumo 550
Woooodentop
Chester Flintshire
Just been touring Scotland in the worst weather ive ever rode in....
After about 3 days started noticing corrosion on the terminals in the cradle...
The next day zumo worked for about 2 hours then went dead....
Tried various on the zumo, charging off the netbook etc but no life....
Where can it be fixed???
What about the cradle???
Any help appreciated...
If you're still in warranty then you should speak to the shop where you got it from. If not, then contact Garmin.
Take out the battery if you haven't already, Wd40 the cradle and Zumo base, gently use a toothbrush on it. if the pins are eaten away then you will need to replace the cradle.
Had the same problem sprayed the contacts with switch cleaner sorted.
Tried spraying contacts which look corroded on the 2 nd from left back, no result.
Have removed battery and re installed, no result.
has anyone used a repairer
