HELP !
P.J.
W. Ireland
. . I have a new laptop (ASUS), router & wireless adaptor. After several attempts @ wiring, I keep losing the service to the PC, which I wish to maintain as well as the ASUS
A bit more detail is needed to suggest a fix
Agreed....not really sure what the problem is P.J :nenau
Do you mean your desktop PC keeps losing connection with the wifi router?
What's the wiring bit that you'd been doing :nenau
Hard wire the PC from the router with an Ethernet cable. Also look at the instructions and make your router SAFE, WPA, firewall etc etc cause someone might be tapping in on your signal.
You've not given much info, so hard to guess :confused:
