Hepco & Becker engine bars and Touratech hard parts query
russ996duke
Cardiff, Wales
I was thinking of fitting a TT hard part to protect the gearbox mount point on my 1100GS......do a little bit off road and the design of this bit of the bike seems cr*p even compared to the rest!:augie
So I contacted TT to ask if the H&B bars I have allowed the fitment of their hardpart as they both seem to locate in and around the same engine bolt area......and they did'nt know!!!:thedummy
soo, here I am asking the assembled knowledge base that is UKGSER (:bow ), anyone have both on their bike?
thanks
Yes the H&B bars and the Gerabox hardpart can go together - I have it on my 1100 but you may need to angle grind a small piece out of the TT hard part on the rear most upper corner. It's only a little bit that needs to be taken off just to allow the H&B bar connector to fit snug. It's a 2 minute job with an angle grinder or 10 minutes with a file. You may get it to fit without and the H&B bars are not an exact bit of precision engineering so you may be lucky and not have to do it.
TT hard part is a very worthwhile investment for any 1100's who plan to go offroad - they may save your gearbox casing.
I was going to ask the same question!...When the replacement bolt is fitted it looks like it also goes through the H&B bar...Is the bolt long enough to go through both and still have sufficient thread left?
cheers mate that is very helpful to know....will now order part from TT despite their lack of product knowledge, lucky arn't they:o
