Hepco & Becker luggage rack
casperghst42
Rodgau, Germany
Hi,
Just fitted the luggage rack to my GS, and as where the right side if fine, the left side is a "problem".
When everything is fitted without using brute force, the screws of the front part is touching the exhaust.
Am I doing something wrong, or is this normal?
Thanks.
Casper
Hi Casper,
which Hepco Becker rack have you fitted. I have a H.B. Rack fitted to my 1200GS and it was a good easy fit. Or do you mean Pannier Frames ?.
Hi Mike,
It's the pannier frame, I've take some photos, which I hope show the problem;
Thanks.
Casper
Like Thunder said, just "Trim" down the screw to leave some clearance. Should be ok.
Got it sorted, got some M6 bolts, I replaced everything with M6 50mm, and for the mount at the exhaust I used M6 40mm which fitted just fine.
Thanks!
Casper
