T900
got a 2001 650gs with 20k on the clock, bought it with broken selectors in the gearbox. fitted new selectors and checked all gears & dogs for any signs of wear as i know the boxes were prone to problems. only broken selector found and i replaced all of them while dismantled. put it all together and runs great, gearbox lovely and smooth.
when in second gear, accelerating hard at 4,000 rpm the bike hesitates for a split second as if you missed a gear or the ignition cut for a split second. you can roll on and off the throttle in second and it will hesitate at 4,000 rpm every time. the clutch is not slipping, definitly not missing a gear, not jumping out of gear, no faults stored in the ECU.
i reckon this caused the selector fail in the first place. any help would be great.
