Hide waypoints?
karnevil
Shotton,N.Wales
My first attempt at puttin a route into my Garmin I put a load of via points as waypoints to get it to do the rout that i wanted it to,The Alps actually,what i had not realised is that i selected show on map and they always show now and it is annoying me.Point is can i "HIDE"them now or do i need to re-enter them and select dont show?
Far better to use the 'route tool' within Mapsource (in the toolbar select the icon with three little squares joined by a red line). Click on your start point and then click along your route to define it, once you reach the last point on your route press the 'Esc' key on your keyboard.
If you need to make changes click the 'select tool' (arrow on the toolbar) and select your route by clicking on it, it should then show as yellow rather than magenta. Once you've done this you can click anywhere on the route and drag a new navigation node to an alternate road to change the route. If you click on an exiting node (little black square) you can move it.
To remove a nav. node click away from the route using the select tool so that it return to magenta and then click the node that you want to remove, it should now be yellow with the route remaining magenta. Press the 'Delete' key on your keyboard and a confirmation dialogue will appear, click 'Yes' and the node will be removed and the route recalculated.
One of the easiest ways to plan a route is to just define the start and end points using the 'route tool' and then use the 'select tool' to refine the route between these two points.
It's best practice to go through the route checking the nav. nodes you've defined in close detail as it's easy to place them just off the route if there's another road close by or on the wrong side of a dual carriageway.
When plotting a route through towns and cites drop your nav. node on the road out of town first, that's all you might need to do. Depending on your unit there is a limit to the number of navigation nodes although I think this is around the 500 mark (on my Quest) which is more than you should ever need.
If there are POIs/waypoints that you do want to visit just select those within your route.
Break your tour up into day long routes (or hotel to lunch and then lunch to hotel, i.e. two routes) rather than have the entire tour as one big route. This way any recalculation is quicker and it allows you to have alternate routes loaded if you so desire. Don't bother to try and get the unit to do ferry crossings, have one route to the departure port and another starting at the arrival port going onward.
If sharing your route any riding buddies they will probably need to recalculate the route in Mapsource if they are using anything other than the exact same version of City Navigator as you.
Bumpkin what a brilliant answer.I have tried that route tool before but never managed to get it to work right now with your explaination i can thanks so much.:beerjug:
No problem. It's a little 'crabby' but once you get used to its foibles plotting in Mapsource is a breeze.
If you plot a route based on waypoints each will be announced as you pass which can be a little distracting. Using the routing tool to add invisible routing nodes prevents this happening unless you intentionally drop a node onto a waypoint.
One thing I noticed today; If you view a route in Google earth you can see the nodes that Mapsource adds to create your route (at least that's what I think they are), there are loads of these, somewhat like looking at a track. Use the 'View' > 'View in Google Earth...' menu command to open your route in Goggle Earth and then zoom into the route, expand the Mapsource tree until you get to 'Routes' > 'Path' > 'your route name' and then right click this and select properties. Lots of little nodes show up, each of which I assume to be the nodes that Mapsource has added to mark your route. It helps if you reduce the opacity of the track making the nodes clearer.
I quite often have a look in Google Earth,but my route all show up as straight lines as if every route was in the off road mode.I must have some settings or summat wrong but to be honest GD baffles me stoopid.:augie
