Hilltop motorcycles
mikecbrxx
Peterborough, UK
There have been several posts about Hilltop and reprogramming the ecu so i decided to go along myself. The results were;
A very different bike. It appears that the stock fuel settings are to run 'lean'. When thats gone, the improvements are obvious. Not cheap but no dearer than a power commander and with less wiring.(none)
Geoff is also a very interesting guy to talk to. A world class paragliding pilot both powered and free. I'll try and get his youtube handle and post some links.
Sent from my SM-N910F using Tapatalk
Not sure about the accuracy of the print outs but after Geoff worked his manic with mine I was left with a completely different bike. Expensive but well worth it for the improvement
I think they do claim something like that though I guess it depends where its measured. And my bike has now done 57,000 kms, so far from new.
I guess they measure it from the crank
Although 10 ponies is a lot to lose on the way to the wheel
Really good to read about your experience with a single. I keep meaning to get my Husky over to Geoff's and this has spurred me on.
The main thing I'm after is smoother low down fuelling (when trickling along at 15/20mph), currently the bike is surging quite a bit at those sort of speeds. Also, I really want improved/instant pick up (more like a carb) for floating the front over obstacles. What improvement did you notice in these areas?
Andres
Andres
Should have kept the 610 :comfort
Andres
All of the above. You will not be disappointed.
