Both my horn and dip beam have failed (at the same time) on my 2004 r1150gsa. Fuse 4 for the horn is ok (indicators are fine), tried a new H1 bulb but nada. Wondering if it might be a fault in the left hand switch cluster - any ideas?
Above or do you run more powerful headlights (considerably over 55/60 watt?) This powrful headlight mod w/o wiring mod can often melt out the main loom from random places (or a whole bike) if you haven't wired it separately with a separate relay.
Thanks all. I'm running standard lamps (as it were...), all the fuses are fine, I'm suspecting the loom although it has had the restrictive headstock cable tie snipped...
